J1D
- Feb 22, 2004
- 259
It’s an old topic, I know some threads talking about “hinged” or “fixed” base in analysis. But a specific question occurs to me from time to time: we often use base plates with four anchor bolts outside of wide flange column, and the column base is modeled as a pin. With different details, such as bolt size, bolt spacing, size of column, thickness of base plate, etc, the rotational rigidity of base plates varies a lot. Conservatively designing the anchor bolt, we can still consider a “fixed” base, but this may cause bolt overstress (at least theoretically) by the bending moment induced. On the other hand, once a base plate has some flexibility the bending moment at base is very small in lot of cases. The uncertainty is caused by the difficulty to model the base plate rigidity.
Any suggestion or practical guidance on to what extent/situation we can confidently assume a four-bolt column base is a pin? Thanks.
