Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You are right.So to get 5kg, I have to input 0.005 in the inertia/point mass. similarly for the shear rigidity I need to input it in Mpa as the stress, right?
In the simplest case yes, but if you have very small time step you have a lot number of increments and then you might have wrong results due to numerical errors.If i choose a smaller value for time increment, would the results be more reliable?
