Right-click menu changed/gone
  • Thread starter Thread starter hall
  • Start date Start date
H
hall
Guest
Right-mouse click on a feature, either on the part itself or in the model tree, normally gives me a menu with Delete, Suppress, Modify, and so on.
Right now, if I right-click on any feature in the model tree from # 1 up to some number, all I get is Info >. If I right-click the same feature on the model, I get Rehighlight, Info >, Next, Previous (grayed out), Show Selection Bin, and Unselect Last.
If I go beyond feature some number, I get the *normal* menu.
What is going on ?? This happened once before and I did something to fix it, but since I'm posting here, obviously I can't remember... :-) It does only appear to be happening with one particular model.
I'm using Pro/Engineer 2001, build code 2002220.
I've found the problem... The feature(s) got tagged as read-only, although I'm not sure how or why. I know that I didn't (intentionally) do it.
