Can't access dimension properties via double click
  • Thread starter Thread starter brysamo
  • Start date Start date
B
brysamo
Guest
I'm using Creo 2.0 and just upgraded from M010 to M240 and now I can't seem to access dimension properties in drawings via double click anymore. Is there a setting or config option to fix this?
B
Edit: this is only an issue for nominal dimensions (which is annoying because when I do "show model dimensions" all items are initially represented as noimnal)
Managed to find what was changed, posting here in case anybody stumbles across this at a later date:
Double click on dimension text opens value EDIT field for all driving dimensions
Double click on dimension witness line opens Dimension Properties dialog
