paduk
- Jul 2, 2007
- 18
I have designed a plant to provide DHW and heating for a building.
By the calculation I have got that the heating loads (peaks) are gonna be:
300kW for heating purposes
175 kW for hot water.
The system is going to be made of:
1 heat pump using borehole water connected to a ceiling radiant system to heat the rooms;
3 boilers to provide hot water and part of the heating load.
Now the problem is I dont know how to split the heating load (300KW)between the heat pump and the boilers.
I was thinking to make the heat pump doing 80% of the heating load and than 20% to the boilers (which are going to do also the hot water) but is just an idea without any sort of theorical support.
Have you ever come across this?
Any ideas?
Any ideas?
