Hi All,
I’m trying to determine if the ridge pole is carrying the load of the rafters regardless of where it is placed.
Situation 1: I put a structural (load bearing) ridge between the rafters and they are secured properly(ties etc.). - I assume the ridge is carrying the load.
Situation 2: I put the exact same structural (load bearing) ridge under the rafters. - - I assume the ridge is carrying the load.
In each case my thought is to determine the load in exactly the same which would mean that the ridge required to carry the load is the same for both. The only difference in the two scenarios is the placement of the ridge. To me, if the rafters are secured properly, in either case the ridge is doing all the work so it doesn’t matter where the rafters are attached. Does this sound right?
Thanks for your time,
Doug
Doug
