I'm reading between the lines that you're only interested in unpowered or passive RFID tags, and that you're not including any consideration of the larger battery-powered RFID tags.
I don't understand why you would be overly worried about the T/R antenna isolation.
It seems obvious that you will often have stronger reflections from the environment, and various items within the environment, than you would from ANY passive or field-powered RFID tag (if for no other reason than the tags are typically so small that they're very power starved).
Unintentional reflectors in the environment would typically be much larger than an intentionally small tag, and such unintentional reflections would often be much stronger than the RFID's 'reply' signal (by orders of magnitude).
Thus, even if you achieved perfect T/R antenna isolation, the perfect isolation would be ruined the first time anything entered the environment (unless it were something made with the very latest stealth technology ;-) ).
Of course, any practical RFID system would require a certain amount of antenna isloation for practical reasons (don't swamp the receiver), but the system design should not depend on a high degree of isolation unless you're planning to aim the system into the empty sky and float the RFID tags across the active area suspended on thin string.
So, aren't these system designed to operate in a manner such that the 'reply' is different than the emitted carrier? Some use frequency doublers; others modulate the field. In other words, the receiver must discriminate the 'reply' signal from the carrier by relying on techniques other than T/R antenna isolation.
Putting it another way:
Would your proposed RFID system work when the tag is attached to a cardboard box containing a product? ...where the product in the cardboard box just happens to be a large (~1m) three-sided corner reflector - open end facing your reader.
I believe that most commercial systems would probably pass this test because they do not rely on a high degree of antenna isolation. They can pull out the reply even buried under numerous reflections, some even Doppler shifted randomly as shoppers and shoplifters pass through the active area.
Apologies if I misunderstood the context of the question.
