Higgler
- Dec 10, 2003
- 997
Maybe someone could point out a good reference book on RF via's and give some general guidance on RF plated thru holes (via's).
I plan on using Rogers Duroid 5880 or similar microwave dielectric. Thickness, 30, 60, 100 mils.
Questions;
1) what is the length/diameter ratio typically used as a maximum?
2) Can the hole be plated only on the inside, or does some copper need to be on both top and bottom surfaces of the circuit card surrounding the drilled hole?
3) When you wish to make a coax using a center contact via plated thru hole surrouded by outer via plated thru holes (as the outer shield of the coax), has anyone experience in doing that up to 18 GHz?
4) What circuit card company would you recommend to lay out and build an RF circuit card up to 18 GHz.
Thanks,
khiggins
Questions;
Thanks,
khiggins
