hey
im designing a rfid system for a project at 915MHz
im getting 5.5dbm out of the transmitter and need approximately 35dbm out of the antenna to compensate for the free space loss and to reach the tag 2m away.
Therefore i basically need a 30db amplifier. the only thing is i cant find a 30db amp that is on an ic. there are 30db amps out there but they are physically too large for my use.
I have been told that i could put 2 amps in series in order to get my 30db gain. eg. 10db amp feeding a 20db amp.
the only thing is the output of the 10db amp has to be lower than the max input power of the 20db amp.
I have done some research into this but cant seem to find a good amp pair to use in my design.
Any help would be appreciated.
Rob
Rob
