FYI
ASME Y14.100 is available for purchase from IHS. For more information, consult with an IHS sales representative by calling 800-854-7179.
ASME Y14.100: Engineering Drawing Practices
Adopted on Jan. 30, 1998 the Department of Defense, DoD.
Date of Issuance: Nov. 23, 2001
Scope
This Standard establishes the essential requirements and reference documents applicable to the preparation and revision of engineering drawings and associated lists. It is essential that this Standard be used in close conjunction with ASME Y14.24, ASME Y14.34M, and ASME Y14.35M.
References
The following is a list of publications referenced in this Standard. When the following American National Standards referred to in this Standard are superseded by a revision approved by the American National Standards Institute (ANSI), the revision shall apply.
ASME (American Society of Mechanical Engineers)
ANSI Y14.6, Screw Thread Representation
ANSI Y14.6aM, Screw Thread Representation (Metric Supplement)
ANSI Y14.7.1, Gear Drawing Standards - Part 1: For Spur, Helical, Double Helical, and Rack
ANSI Y14.7.2, Gear and Spline Drawing Standards - Part 2: Bevel and Hypoid Gears
ANSI Y14.13M, Mechanical Spring Representation
ANSI Y32.10, Graphic Symbols for Fluid Power Diagrams
AIIM (Association for Information and Image Management)
ANSI/AIIM MS4, Flowchart Symbols and Their Use in Micrographics
AWS (American Welding Society)
ANSI/AWS A2.4, Standard Symbols for Welding, Brazing, and Nondestructive Examination
ANSI/AWS A3.0, Welding Terms and Definitions, Including Terms for Brazing, Soldering, Thermal Spraying, and Thermal Cutting
IEEE (Institute of Electrical and Electronics Engineers)
ANSI/IEEE 91, Graphic Symbols for Logic Functions
ANSI/IEEE 200, Reference Designations for Electrical and Electronic Parts and Equipment
ANSI/IEEE 260.1, Letter Symbols for Units of Measurement (SI Units, Customary Inch-Pound Units, and Certain Other Units)
ANSI/IEEE 260.3, Mathematical Signs and Symbols for Use in Physical Sciences and Technology
ANSI/IEEE 268, Standard Metric Practice
ANSI/IEEE 280, Letter Symbols for Quantities Used in Electrical Science and Electrical Engineering (Same as ANSI Y10.5)
ANSI/IEEE 315a, Supplement to Graphic Symbols for Electrical and Electronics Diagrams
ANSI/IEEE 991, Logic Circuit Diagrams
IEEE 91a, Supplement to Graphic Symbols for Logic Functions
IEEE 315, Graphic Symbols for Electrical and Electronics Diagrams
IPC (Institute for Interconnecting and Packaging Electronic Circuits)
ANSI/IPC D-350, Printed Board Description in Digital Form
ANSI/IPC T-50F, Terms and Definitions for Interconnecting and Packaging Electronic Circuits
IPC D-325, Documentation Requirements for Printed Boards, Assemblies, and Support Drawings
IPC 2221, Generic Standard on Printing Wiring Board Design
ASME B46.1, Surface Texture (Surface Roughness, Waviness, and Lay)
ASME Y14.1, Decimal Inch Drawing Sheet Size and Format
ASME Y14.1M, Metric Drawing Sheet Size and Format
ASME Y14.2M, Line Conventions and Lettering
ASME Y14.3M, Multi- and Sectional-View Drawings
ASME Y14.4M, Pictorial Drawing
ASME Y14.5M, Dimensioning and Tolerancing
ASME Y14.8M, Castings and Forgings
ASME/ANSI Y14.18M, Optical Parts
ASME Y14.24, Types and Applications of Engineering Drawings
ASME Y14.34M, Associated Lists
ASME Y14.35M, Revision of Engineering Drawings and Associated Documents
ASME Y14.36M, Surface Texture Symbols
ASME Y14.38, Abbreviations and Acronyms
ASME Y32.2.6, Graphic Symbols for Heat-Power Apparatus
ASTM (ASTM International)
ASTM E 380, Standard Practice for the Use of the International System of Units (SI)
ASTM F 856, Standard Practice for Symbols - Heating, Ventilation, and Air Conditioning (HVAC)
ASTM F 1000, Standard Practice for Piping Systems Drawing Symbols
EIA (Electronic Industries Alliance)
EIA 632, Processes for Engineering a System
SAE (Society of Automotive Engineers)
SAE AS 1290, Graphic Symbols for Aircraft Hydraulic and Pneumatic Systems
IHS and ASME
IHS has been the leading distributor of ASME standards and codes since 1974. In 1989, IHS and ASME first produced a full-text, electronically searchable, hyperlinked version of the ASME Boiler and Pressure Vessel Code on CD-ROM. The 2004 edition is now available.
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
