tc7
- Mar 17, 2003
- 387
A new welder is showing a performance test from previous experience as follows:
ASME Sect IX/AWS D1.1
Pipe
6G
A53 Schedule 80; 6-inch nominal
SMAW/GTAW
Fillers: ER70-S/7018
No backing strip
Radiograph results were:
1-2 OK
2-3 OK
3-4 1F
4-5 OK
5-6 1F
6-1 1F (1F = small porosity)
Final determination by Inspector: ACCEPTED
My Section IX assesment:
1. Since QW-304 permits an alternative RT method of qualification, no other mechanical testing or visual testing is required for this welder;
2. welder may weld any and all P-1 materials (all groups) and all P numbers upto P11 plus P34 & P42;
3. welder may use any, all and only F-6 fillers for TIG root up to 2T of that deposited in qual test, on plate or pipe subject to appropriateness of the filler to base (& qualified WPS);
4. welder may use any, all and only F-4 fillers for SMAW up to 2T of that deposited in qual test, on plate or pipe, subject to appropriateness of the filler to base (& qualified WPS);
5. welder may weld any position, plate or pipe;
6. welder may weld all pipe greater than and including 2 1/2” sched 40.
7. welder may weld any thickness plate greater than ????;
8. welder may not weld plate thickness less than or equal to ?????;
9. since no solid backing was used in test, welder may weld with or w/o solid backing;
10. since no purge gas was used, welder may weld with or w/o purge gas.
My questions:
a. any and all comments on above, please!!
b. Any additional facts and observation regarding the welders test?
c. Cannot find specific Sect IX paragraphs to support 7, 8, 9, 10 above.
d. Thankyou for you help and interest.
Tom
Pipe
6G
SMAW/GTAW
No backing strip
1-2 OK
2-3 OK
3-4 1F
4-5 OK
5-6 1F
My questions:
Tom
