Reverse Wheel zoom in Wildfire
PieBoy
38
I've had a search but not found anything suitable.
I use Autocad 2005 LT amd Wildfire 2.0. As you may know the zoom wheel on the programs are the oppersite way around to each other.
It's only a little niggle when moving from one to another but is is possible to change ProE Wildfire zoom to work in the opposite direction?
Cheers all
Mark
I don't think so.
Inventor is also opposite. There is an arx that can be updated to reverse the zoom direction on Acad and its verticals. You might see if there's a patch for LT as well.
Quite comical that almost everything on ProE is adjustable in some way.
Ah well thanks for the advice.
