reverse view - Solid Edge
alexgardin
CA
In model creation mode: When in sketch, or when the 'normal to plane' button is pressed how do you reverse the view ie. flip 180deg?
If it's a "normal" view you can use the quick view cube otherwise I use the left/right arrow keys - 12 hits for 180 degrees.
The F (flip), B (back) and N (next) keys will change the orientation of the origin during plane creation.
Kyle
