Hi Keith,
I was looking in the Brook crompton page and I found this:
" Permanent Capacitor - PDA
Standard Design: Direct-on-line starting only, with any spot voltage between 200-250 volts available. Suitable for fans blowers and centrifugal pump drives with light starting requirements. Starting torque is between 25% and 55% of full load torque, according to frame size. Clockwise or anticlockwise rotation of the shaft is available by re-connection. Available in outputs from 0.09kW to 2.2kW, frame sizes PDA63S to 2-PDA90L, in 2 and 4 pole speeds.
High Torque Design: As above but with a higher starting torque of between 70% and 80% of full load dependent on frame size. Available in outputs from 0.37kW to 1.1kW, frame sizes 2-PDA80M and 2-PDA90L, in 4 pole speed.
Variable Voltage Speed Control Design: For use on variable voltage (thyristor) speed control such as fan applications. Available in outputs from 0.37kW to 1.1kW, frame sizes 2-PDA80M and 2-PDA90L, in 2 and 4 pole speeds.
Capacitor Start- EDA/TDA
Available in either Capacitor start/Induction run (EDA) design - vailable in outputs from 0.12kW to 1.5kW, frame sizes 2-EDA71M and 2-EDA90L, in 2 and 4 pole speeds, or Capacitor start/Capacitor run (TDA) design, available in outputs from 0.18kW to 3kW, frame sizes 2-TDA71M to 2-TDA100L, in 2, 4 and 6 pole speeds. Direct-on-line starting with any spot voltage between 200-500 volts available. High starting performances suitable for industrial and agricultural applications of a more demanding nature. Starting torque is between 160% and 300% of full load torque according to frame size. Clockwise or anti-clockwise rotation of the shaft is available by re-connection"
Maybe you need the to do the right connections and wire proper the motor.
Carlos
