Rev Letters 1
LADO
Military
Does anyone know where I may get a standard on what letters are not used on a revision block due to mix-up with a number?
ASME Y14.35 &/or ASME Y14.100.
I have neither to hand right now but basically don't use the ones that can look like numbers. I think this has been discussed before if not here then on forum781.
KENAT,
Have you reminded yourself of faq731-376 recently, or taken a look at posting policies: What is Engineering anyway: faq1088-1484
What if I needed to go to "AAA"? ;-)
"Good to know you got shoes to wear when you find the floor." - [small]Robert Hunter[/small]
ewh,
I know you are kidding, but yeah, I thought about that seriously. I read the standard carefully. Technically, triple letters are not prohibited, but they are also not mentioned by the standard. So I figured YY was a less than arbitrary point to stop the list.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
Question for FCSUPER:
Could you please direct me to the article where I can find the "complete" list of the ASME acceptable rev. letters? I would like to thank you for your list but I need to pass on formal literature on the subject. I've look in ASME and can't find it.
THANKS to all for your help!!!
ASME Y14.35M-1997 Section 5.
5.1 Revision Letters said:
... omitting letters "I," "O," "Q," "S," "X," and "Z".
KENAT,
