LER57
- Jun 26, 2009
- 2
We have a rentention wall slab that is 65' long, 7 ' tall with an attached, supported poured concrete slab. The slab area is a pool deck with the pool being 25' from the retention wall. Approximately 6' of the rentention wall has settled about 2" on just one side. The supported slab that is attached to that portion of the rentention wall settled recently about 1" down, on the inside area,(away from the wall) where the slabs come together to form an overflow drain line for the pool. It is the only area that has settled. The retention wall also has 5 - 2" drain holes, drilled out several years ago, for some unknown reason, 2 of the drain holes that are inline with the slab that has settled, have been recently letting the sand/backfill drain out of them at an increasing amount. I suspect a major shift in the back fill under that portion of the slab(s) however most of the other suggestions say it was just a small wash out and that the slab can be fixed without any major work. I would like some comments or suggestions on this.Thanks Larry
