Retaining Snap Rings For Slotted Nut
byrdj
1,663
Is this a standard Snap Ring or something special for the application?
links to available requested.
getfile.aspx
 http://files.engineering.com/getfile.aspx?folder=cd624f85-4d4f-431f-837c-e6114fd997c3&file=BRAKE_CLIP.JPG
It doesn't look standard, though.
If you need a bunch of the exact same ring,
make a spec drawing and fax it to everybody.
Whoever quotes it cheap with no tooling charge, already has the tools.
Mike Halloran
Pembroke Pines, FL, USA
Maybe I should have posted in "Hobby" as a friend only needs a couple. It is used in a parking brake actuator for 70's car. I was hoping it was a DIN/SAE standard I had never encountered
CoryPad, notice the ID is the circle but the "key" extends to prevent rotation of the inner castle nut.
Yes, I am familiar with the style, we used it at GM over 15 years ago.
Is there a “description” different than what I am calling it that could help locate them?
while finding a part to use is part of the search, my inquiry was more for defining that type of part.
in this case, the clip was used in Girling rear calipers w/park brake, from early 70's deTomaso.
Here is a link where a new one can be purchased
But, I am still interested in determining if a generic part.
This is likely a special/OEM.
