Hi everybody!
I've got a question about results I obtain from SOL101 and SOL106, which are massively different, so I wonder which one is the most accurate.
The analysis is a pressurized plate, pinned at both ends.
Linear Static analysis predicts a pretty large deflection, and a high max stress.
However, the non linear one shows a small deflection and lower stresses.
So it seems that with the non linear analysis, the plate stiffness increases, but as we consider large displacement I was expecting a greater deflection.
Also, linear predicts a large bending moment, while the non linear shows high tension force on the plate (I guess what we call follower force). But I cannot really understanding physically how it works.
Thus, I'm a bit puzzled about how to decide which result is valid, and more generally how to have the flavour of the behiavour of the structure to choose between 101 and 106.
Thanks a lot for your help on that!
Cheers
Cheers
