Results to datafile 1
siggi84
IS
I have one problem with ansys. What is the easiest way to write ansys results (i.e. temperature and electric field) to a datafile. I want to select all the nodes adjacent to a line (using the NSLL command) and write out their position, temperature and electric field in a separate file.
How can I do that?
Best regards,
siggi84
If you use the *vget command, then *vwrite. You have to also use *cfopen and *cfclose. What this does is write vectors to a text file, so if you use *vget to get the vectors of positions, temperatures etc then you should end up with a text file containing the values that you require.
Excellent, I got this working. Thank you.
