I'd like some educated guesses about what would/might happen if the Viper's plenums were connected. There is a core plug at the back of each plenum. I could join them with some plumbing and have a solenoid actuated valve in the middle opened by a rpm switch at 4500rpm or so.
This question doesn't have to be Viper specific,and the rpm is just a 'for instance' ..
Anyway, let's stick with the basic configuration of 5, or 4 (doesn't matter I guess) cylinders per side. If the longish intake runners aren't changing their length, it doesn't look like a first thought that the powerband peak would be raised or extended, though the plenum volume would effectively double. The route from one plenum to the other might be less than 2" in diameter
The rear most cylinders are known to run a little rich anyway since they're waaay at the back of the plenums, so they might welcome the added air reserve at high rpm.
Then again might coupling the plenums throw everything off reduce cfm into the runners and I'd lose power?
More importantly if I did try it once would there be a danger of some near immediate catastrophy as I winged past 4500rpm and the connecting valve opened?
Near stock Viper engines run little vacuum at WOT which is probably why they don't respond well to larger throttle bodies.
I just don't want to have all Hell breaking loose inside on that first attempt(!).
Might be something better tried on a dyno first rather than on the road.
