I have a problem in a project i am working in now (still in the engineering phase).
The purge line for the flare is from the discharge of a compressor. so the design was to place a restriction orifice to drop the pressure from 1500 psi to 20 psi. I calculated the bore diameter of the RO and it was found to be 4 mm. The temperature downstream of the RO will drop to -35 C. The process engineer said that hydrates will form so decided to inject methanol upstream of the RO to prevent hydrate formation. The problem is that the required methanol injection for hydrate prevention made the stream a 2 phase flow (gas +2% methanol). I cannot place a drain hole because the drain hole should not exceed 1/10 of the RO bore which will yield a a drain hole diameter of 0.4 mm which is not practical. Also if i used a standard drain hole of 2 mm the flow will increase dramatically (because the drain hole diameter will be 1/2 the bore diameter). I am concerned about the accumulation of the liquid (methanol) at the RO upstream face. Note that this is the only source of purge for the flare and if it got plugged a flare flashback might occur.
Any ideas?
Any ideas?
