Hi All,
What are the standards for sizing of restriction orifices? Needed for liquid and gas-liquid flow. Does AGA 3, ISO 5167-2, ASME MFC 3M really highlight this issue? I went through them but not satisfactory and specific.
The calculation can be done but the thing is the CONSIDERATIONS. For example, the upstream pressure and downstream pressure of a RO is 1000 psig and 80 psig accordingly. Is it possible doing this DP using single RO? When to use multiple RO? How to measure cavitation after RO? IF RO is after control valve, then what should be the upstream pressure of RO? what is the allowable/suitable range of beta ratio for RO? etc ,,,,
Is there any standards or guidelines which is specific for RO (for liquid services), not for in-general orifice plate?
Thanks in advance.
Thanks in advance.
