Z
zimmy
Guest
I have a parameter (string) controlled by an external file ( restricted val definition ).
No problem if I change the parameter value directly using the drop-down menu in the parameter panel.
But if I change the value in Relation panel for special conditions
IF ...
parameter_name =="xxx"
ENDIF
ProE can't change the parameter and an error comes up !
Same problem with other types of Parameters (number ,...)
I tried with WF5 and Creo1.
Any idea ?
Thanks a lot
Pier
IF ...
ENDIF
Any idea ?
Thanks a lot
Pier
