JGov
- Nov 17, 2016
- 3
I am trying to calculate the amount of dead pipe required to be left in the ground behind a cut/capping of an existing water main. The main is 24" D.I. and will be capped temporarily until we come back to tie into the main with new pipe. I've attached two different calculations I've done to determine the amount of pipe required to be left in the ground behind the cap to resist potential thrust forces via the friction resistance between the dead pipe and the soil: one done through a DIPRA exercise and one done through an exercise found in ASCE Buried Flexible Steel Pipe textbook.
Why are the two analyses giving me such disparate results? Is the force exerted on the pipe by the soil in the Buried Flexible Steel Pipe textbook analysis correct?
