Restart analysis
txrobo
Hi
I'm a new member of this forum and fairly new to ABAQUS. I was wondering if it is possible to run an analysis using one method and then restart it from a certain increment using a different method. Also, does the first analysis have to complete for it to be restarted?
Hi txrobo,
There is *Restart command in Abaqus to fullfill your goal.
First step, to do first step analysis with *RESTART,WRITE,... Options.
Sencond step, to do sencond step use different method, by
*Restart, Read,... Options.
Or you can also try *IMPORT,... Command.
Hope it would help you!!
Good luck.
Charle
