Resource Help!
bonkers
ASME BPVC Sect. VIII Div. 1 Appendix 1-5 (g) states that conical sections (cone-to-cylinder junction) with a half-apex angle greater than 30 degrees may be used if the design is based on special analysis, such as the beam-on-elastic foundation analysis of Tomoshenko, Hetenyi, or Watts and Lang. Does anyone know where to find these resources and how it applies to vessel cylinders as opposed to a beam? I have an eccentric 36" x 16" cone reducer 24" long with an angle of 39.8 degrees which may or may not require reinforcement.
Thank you for your thoughts!
Bonkers
See "Pressure Vessel Design Handbook", Henry Bednar, Section 8.6.
Other references are available too. Get ready for some complex calculating.
My thought would be to stretch your cone:)
Mike
Thanks guys, good suggestions. I will research the PV Design Handbook but I don't like complex calculating, just the ordinary kind. My original design to the client did have a "stretched" cone of 34 11/16" with a 30 degree angle. The client advised that he has bought a cone and it was a "standard" 24" size. I didn't know that these were standard available components. I told him that I would inquire to see if I can determine if he can use it. Thus, my request for a resource.
Thanks,
Going Bonkers
Is this a standard 24" pipe reducer? Produced to ASME B16.9 pipe fittings standard? If so, then simply use the rules of UG-44 to rate the reducer to same MAWP as for straight pipe of same schedule. Easy.
Tom,
This is suposed to be a straight wall eccentric cone reducer without any "knuckle " radius for PV shell. Material SA-516 70N, 1" thick. Not pipe.
-Bonkers
bonkers, did the client get a Partial Data Report with his cone? This is almost certainly NOT a standard part.
Mike
Would add, if it IS a standard part the manufacturer should provide a rating and documentation.
