Hello everyone.
I'm new in this forum and also in abaqus analysis.
I'm trying to model a resonant bending fatigue test in abaqus but I have some problems.
The experimental test has an eccentric mass at the pipe tip which rotates, generating the pipe oscillation.
First I used a linear perturbation-frequency step to check the natural frequency and the nodes positions for the first mode.
Then, I tried to use "steady state dynamics, direct" step (with a frequency close to the natural frequency) and applied a downward force equal to the centripetal force (caused by the mass) at the pipe tip .
However, I'm not sure if its the right way to model that, since I'm not familiar with this kind of simulation.
What I need as a final response is the stress levels and the aceleration so I can compare with experimental data.
Can someone help me with that?
Thanks in advance.
Thanks in advance.
