I work at a power plant and have a project to replace a couple pumps used for routine washes (boiler wash pumps 51&81). These pumps have a reoccurring problem and have to be put out of service, pulled out and repaired because of vibration caused from the shaft bending - breaking the mechanical seal.
BWP #51 was replaced in 2008 from 50hp 235gpm 420ft head to 125hp 525gpm 600ft head. BWP #81 was replaced in 2010 (a one for one replacement: 125hp 525gpm 600ft head). Im not 100% sure why they were replaced, but I think both were replaced due to corrosion. The water used for these washes is from a stream and corrodes the inside of the pipe (and probably the pump column). Since the BWP# 51 replacement in 2008, maintenance has pulled out and repaired this pump in 2012, 14 and 15. Since the BWP# 81 replacement in 2010, maintenance has pulled out and repaired this pump In 2012, 13 and 14.
I attached the pump curve for both pumps with the measured head and flow plotted on it to see where it is operating relative to its pump curve. My question, is this even possible to get data like this? I was expecting the points to be riding along the pump curve, but its not, it looks like the head is held constant no matter what flow it provides. Im using an external flow meter attached to the supply and recirculation line to the pump (measure just one pump- only one pump is running at a time). The head is being measured from the discharge of the pump, by a pressure data logger.
The system setup, is a 6" supply line and a 2" recirculation line with a control valve set at 200 psig. These pumps are vertical centrifugal pumps, getting the water from a pit about 8' deep (constant supply of water). Different washes require different flow demands, so it's not just one flow-head needed.
I also attached the pump outline, and a plan view sketch showing where the data loggers are set up. The piping was corroded and the external flow meter wouldn't read any flow, so I replaced portions of the pipe to be able to measure flow. Also, theres a question of if the flow meter is reading accurate flow, the 2" line the flow meter would have problems getting data and I spent many hours fiddling with the sensors mounting-remounting in order to get a reading. the sonic velocity that the flow meter gave to me is:
6" line: between 1482 (m/s) - 1520 (m/s) [average 1488]
2" line: between 1295 - 1778 (m/s) [average 1407]
any help / advice would be greatly appreciated. thanks everyone!
