Practicalguy
Chemical
Hi All
I'm changing impeller from 8 inches to 8.5 inches and I want to confirm the motor size of 20 HP is adequate or not?
I have an existing pump with an 8" impeller with a differential head of 242 ft and a flow of 220 gpm read from the curve with an efficiency of 64% and a motor eff of 91%, I get a 15.4 BHP
To double check the calculations, I went and took amps reading and read 13.4 amps. The full load amps is 18.4 amps
I used the actual amps reading of 13.4 and calculated the power by using the formula VxIxPFx1.73xEff/746 = 15.2 hp. The two numbers are pretty darn close..
Ok having done all that, I still don't know the system resistance when I can put the new impeller in service. With the new impeller in service the pump will try to put more flow and head and the system will be hydraulically balanced and the pump will ride the curve. supposedly I maintain the same flow of 220 gpm, the new head on 8.5 inch will be 290 feet. The new calculated power will be 18.5 hP
I've talked to the pump vendor and he confirmed that 20 Hp will be enough. The motor has a SF of 1.15
I want an expert opinion in this matter whether to change the motor or not?
Thanks in advance for your help
Practicalengr
Practicalengr
