Hi All,
I've got a project that uses a rectifier, and outputs to 5 locations.
I need to build a load cell for each output. The resistance value will be 13Ohms. Power dissipation through each load will be 32.5KW for roughly 15 seconds.
My question is, how would you go about selecting a resistor capable of this. I have checked around and it looks like 1000W resistors are about the max of what I can find. I assume I wouldn't need a bunch of 33kW resistors....but how do you know the minimum you can get away with without burning up the components for x amount of time?
Thx much
Thx much
