I am trying to determine the resistance coefficient, K, of a single-offset, butterfly style damper. Since, there is no readily available data for dampers I was going to utilize the K values of butterfly valves. Unfortunately, the formulas available are limited to sizes below that which I am looking for.
On page A-29 of Crane Technical Paper No. 410, they list formulas for determining the K value for butterfly valves of sizes 2 to 8", 10 to 14" and 16 to 24". The formulas are K = 45 ft, 35 ft and 25 ft respectively, where ft is the friction factor in a zone of complete turbulence.
The dampers that I need to determine the K values for for 8 sizes up to and including 84".
The following link shows that the K value of a butterfly valve decreases as the diameter increases.
However, some tables that I have for "Sizing Coefficients of Rotary-Shaft Valve Bodies" show a Kc value (which I am assuming is the resistance coefficient) of 0.26 for "rotary-eccentric disc" and 0.25 "butterfly-conventional disc" under a heading of "Valve and Trim Style" for 90 degrees of valve opening. Unfortunately I do not know the source of these tables.
I was hoping someone might be able to help clear my confusion and provide some answers. Your help would be greatly appreciated.
