Residue on Soap-drawn Stainless steel
BMccarthy81
At my company we precision grind 304, 316 stainless steel wire (.125 to .011) to tolerances of +/-.0002 of an inch with #2 cincinnatti centerless grinders (om/ae). the material that we use for inventory and most of our customer supplied material is soap drawn stock. We've always had a problem with the residue/soap that is on the surface of our wire. It gums up our machines and gets on the surface of our grinding wheels. I'd Like to know if there is a cleaning process that could remove this residue from our material without altering the physical attributes of our wire. Any input would be great. thank you.
Without knowing the specifics of the soap, cleaning recommendations are difficult. As I see it, you have three options: a) contact a company specializing in cleaning; b) contact your customer to provide guidance; or c) try to figure it out yourself.
Generic cleaning methods available to you are physical (wipe, scrape, etc.), chemical (solvent or detergent), steam (low or high pressure).
As a note, I work for a chemical company that makes liquid detergents/cleaners. We used to make a hard soap stock that our old-timers remember as being damn near impossible to clean.
Is the soap truly needed?
Can you remove the soap earlier in your process?
