Redacted
- Mar 12, 2016
- 160
Hi there,
I am looking to create a new opening in a residential dwelling and was looking at potentially using a steel beam as the opening lintel instead of a concrete beam, as it seems it would be faster to install and the steel beam itself is not too costly.
However, I am not too sure about how to detail the connection between the steel and concrete wall. I was thinking of creating a pocket for the steel beam to bear on, on both sides, resting the steel beam in place, shimming the steel beam up to become engaged with the block work above and concreting the pocket. For an architectural standpoint, I was going to put drywall or something up to make the wall look like it was fully concrete.
I have sized two beams to work for the application : a W6x20 and a W8x31. However, the wall that the beam would hold up is 10" thick and if I use the 6x20, there would be a 2" overhang on either side, is this acceptable?
Bending strength of the beam didn't govern the calculations, the deflection did. With the 6x20 I am getting a8mm center deflection (with factored loads), and with the 8x31, I am getting 3.1x10-7mm. If I use the 6x20, one concern is this mid deflection, I assume I would need to bolt the beam mid span to the wall above. With such a low deflection for the W8x31, I don't think I would need to do this.
The W8x31 is about $400 more than the W6x20.
What are your thoughts on which size to go with? Also, any advice on the connection detail when dealing with small loads?
