I totally see your predicament SD2.. I backcheck submitted sprinkler shops against engineered sprinkler plans and I sometimes see the sprinkler subs fixing mistakes the engineer made.. I also see them leave in the mistakes, but I am not privy to the fingerpointing that certainly happens when I write up those mistakes. I'm sure it is not pretty and involves the engineer saying "our massive specs require you to put pipe dope only on the outside of threads, and also include the CYA clause that says design and install in accordance with NFPA 13 and governing codes and standards.. " and the sprinkler sub saying "I built the ____ exactly like your drawing shows, and you didn't show ____". Then the engineer says, "in spec __ it says when there is a conflict, the specs govern.. And the specs require NFPA 13 and all other governing codes and standards, which means you were required to put in ___ required by the local code ___."
The best solution to this issue is to review and force quality from the engineer. If the bidding sprinkler sub can't report it due to politics, then it has to start with the AHJ reviewing the engineer's plans.
I don't get to see all our engineered sprinkler plans to fix them, and the other engineers frankly don't have the skill to review them in the very short time they have to review and formally comment on the plumbing, HVAC, Energy Compliance, LEED, and Fire Protection. We get about 6 hours to review all this for the typical 2 to 10 million dollar projects. That can be a set of 75 drawings and two 4" binders filled with specs, design narrative and calcs. in 6 hours.
I know we had this discussion already where someone blasted me for saying an AHJ can very easily miss one line in a hydraulic calc regarding flex hose equivalent length and not comparing it against the vendor cutsheet. I thought they were way off base in disagreeing with that.
Compare that to your experience.. You estimated a 95% failure rate on AHJs enforcing NFPA 13 requirements for seismic bracing, and have experienced a great many cases where the engineer's mistakes were not caught and yet the plans were still approved for the construction permit.
I know there is no easy solution to bad engineers especially when followed up with poor plans review by the AHJ, but I am sympathetic to the situation from your perspectives.. All I can say is if everyone out there put as much effort into learning as we forum regulars do, then none of us would have much left to complain about.
Real world knowledge doesn't fall out of the sky on a parachute, but rather is gained in small increments during moments of panic or curiosity.
