I have a question for experienced foundation engineers regarding SOG on expansive soil.
I need to design a residential SOG. The soil analysis gives Plasticity Indicies of 29 from the surface down to about 10', then 32 from 10' down to 15'.
I went through the WRI method for slab on grade design and feel good about grade beam spacing, depth, reinforcing, etc. But I'm wondering if a portion of the soil should be replaced w/ low PI fill as well.
Even if the foundation is designed to handle the potential differential movement, should I still remove and replace a portion of the in-situ soil to reduce the potential movement? Thanks for any advice.
