shacked
- Aug 6, 2007
- 182
Preface: The majority of my projects are residential, therefore the loading that I encounter for design purposes is relatively low.
I'm designing an attached 250sf open patio roof and I am using 2 steel cantilever columns to resist lateral seismic loading at the free edge, furthest from the house.
Knowns: HSS4x4x5/16 columns, Axial load = DL+Lr = 3.6kips, Design seismic moment at base of column = 11.0kip-ft.
Designing the column as fixed, therefore the baseplate design is to resist bending. Using AISC 360 requirements the required thickness is 1 inch. This seems excessive for a lightweight patio roof. I see that size of baseplate being used for traffic lights approximatelly 15ft tall that cantilever 10-15ft over the street width.
Is there a way, other than fully embedding the steel column in the footing, that could be used to reduce the bending in the baseplate?
Tie the column into the concrete slab?
Thanks.
Thanks.
