SteelPE
- Mar 9, 2006
- 2,759
About a week or so ago I was asked to go look at some “foundation” issues for a client who owns a residential property. The property was built in 2016/2017. No structural drawings were provided for my review, and I have been told no structural drawings are available for review. Based upon historical construction practices for the area I would anticipate an unreinforced poured in place foundation wall to extend 4’-0” below frost elevation…. This wall would be supported by a 20” wide footing. However, this is just a guess I have no other information to go by.
While onsite I met the owner of the property who informed me that the cracks that were observed in the foundation/slab. The owner is concerned because the cracks have only been observed in the past 2 years (appearing 3+/- years after she had moved into the property). Attached you will find some of the notes that I made while I was onsite.
While onsite I observed some rather large cracks that I observed in the slab on grade (larger than what I have seen in the past). That being said, I did not observe any locations for shrinkage relief in the slab on grade…. And with a 50’ slab pour I would anticipate some amount of shrinkage cracks to form right after the concrete is placed… and at point of restraint (which was where the observed cracks were forming) but to have them show up 3 years after construction in an enigma.
I also observed cracking in the exposed foundation walls. Most of this cracking was observed at points of restraint in the wall (at change in directions) and at locations where the wall steps (varying support restraint of the wall). Cracks were observed under one beam bearing locations; however, this was also at a change in direction of the perimeter wall (points of restraint).
Does anyone have any insight as to what might be cause the issues observed onsite?
Part of me wants to say that the cracks are not much of a concern as they were observed in a slab, but then again, they are quite large.
