Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module componentOriginalPosition
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
Sub Main()
Dim selectedComponent As NXObject
If SelectComponent(selectedComponent) = Selection.Response.Cancel Then
Exit Sub
End If
Dim myInterpartDelay As Boolean = theSession.UpdateManager.InterpartDelay
Dim pt As Point3d
Dim RotMat As Matrix3x3
Dim pt2 As Vector3d
Dim RotMat2 As Matrix3x3
Dim SelComp As NXOpen.Assemblies.Component
SelComp = selectedComponent
SelComp.GetPosition(pt, RotMat)
'msgbox("Translation: " & pt.x & ", " & pt.y & ", " & pt.z)
'msgbox("Rotation: " & vbcrlf & _
' RotMat.xx & ", " & RotMat.xy & ", " & RotMat.xz & vbcrlf & _
' RotMat.yx & ", " & RotMat.yy & ", " & RotMat.yz & vbcrlf & _
' RotMat.zx & ", " & RotMat.zy & ", " & RotMat.zz)
'no translation of component on first pass
pt2.X = 0
pt2.Y = 0
pt2.Z = 0
'transpose of the rotation matrix, undo any rotations on the component
RotMat2.Xx = RotMat.Xx
RotMat2.Xy = RotMat.Yx
RotMat2.Xz = RotMat.Zx
RotMat2.Yx = RotMat.Xy
RotMat2.Yy = RotMat.Yy
RotMat2.Yz = RotMat.Zy
RotMat2.Zx = RotMat.Xz
RotMat2.Zy = RotMat.Yz
RotMat2.Zz = RotMat.Zz
'avoid problems if the part contains wave links or other interpart data
theSession.UpdateManager.InterpartDelay = True
'move the component back to the original rotation
workPart.ComponentAssembly.MoveComponent(SelComp, pt2, RotMat2)
'get the translation information again, now that the component has been rotated back to absolute
'negate the translations that have been applied to the component
pt2.X = -pt.X
pt2.Y = -pt.Y
pt2.Z = -pt.Z
'set rotation matrix to identity matrix, we want no new rotations on the component
'or simply use RotMat returned from GetPosition, as it will be the identity matrix
'after the component has been rotated back to its original position
RotMat2.Xx = 1
RotMat2.Xy = 0
RotMat2.Xz = 0
RotMat2.Yx = 0
RotMat2.Yy = 1
RotMat2.Yz = 0
RotMat2.Zx = 0
RotMat2.Zy = 0
RotMat2.Zz = 1
'translate component back to 0,0,0
'reset interpart delay to original value
theSession.UpdateManager.InterpartDelay = myInterpartDelay
End Sub
Function SelectComponent(ByRef selObj As NXObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim message As String = "Select Component"
Dim title As String = "Select an object"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim cursor As Point3d
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_component_type
.Subtype = UFConstants.UF_all_subtype
End With
Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(message, _
title, scope, selAction, _
includeFeatures, keepHighlighted, selectionMask_array, _
selObj, cursor)
If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
