OilBoiler
Chemical
- Aug 5, 2003
- 43
Hi everybody,
I have a question regarding orifice transmitter ranges. If you have a maximum dP range of 0-250 in H2O is there a common practice to design the plate so that the range is only 100 in H2O? In other words, would it affect accuracy if you instead range it for 175, 200, or even the 250 in H2O?
I need to re range current orifice meters and I need to increase the flow and I was wondering if there is a recommended maximum dP that we should design for. Thanks!
