Required Minimum Copper Content 2
QANo1
Materials
Regarding minimum copper content requirements for some materials in ASME Section IIA, how does everyone interpret "when copper steel is specified?"
when copper-bearing steel is specified..
Perhaps someone can offer up more information-
Some of the old tank standards have similar wording about the copper. It says "When copper-bearing steel is specified..." but doesn't say why anyone would do that.
My understanding is that it was done for increased corrosion resistance.
But I've never actually seen copper-bearing steel specified. The closest thing I have seen is use of Corten or similar generic weathering steels.
So I'm assuming that statement is a relic of years gone by.
And perhaps this is the case in the vessel industry as well.
The use of copper as an alloying element with mass content below 0.35% increases atmospheric corrosion resistance of steel.
Copper-bearing steel is far from gone. It's just often called by the trademark name: Monel.
I am still not understanding why this would be in the specs for mild steel materials, such as 414G, for example, if a customer could/would simply just specify a copper-bearing steel (Monel or other) if necessary for their job. I guess I could just assume that they would want the benefit of both materials combined. If that is correct, I have my answer. Like JStephen, I have never actually seen it specified. Thanks for the replies.
Copper bearing steel has no relation to Monel ( a nickel copper alloy). Think of copper bearing steels for use in applications where Corten would be used at somewhat lower cost.
