Hi folks,
I have been digging around for a definitive answer on this. I haven't seen much in Y14.5-2009 (although our drawings don't state any standard, but that's another conversation). I have seen some other people bring this up here and other places, but the conversation seems to get sidetracked. What I have seen is that a datum may be shown in more than one view on the same sheet, and it need not be identified as a reference.
I have a drawing here for a machining step to be done out of house after we weld it together. This machining step will put a hole (shown top right) through six lugs (bottom left) to create a hinge that will support the structure and two holes in the bottom that will allow pins to transfer the load from below. This will straddle a beam with a load hanging from it.
Keep in mind this is a snip. I think I have included all the relevant information, but these features are fully defined in terms of location in other views.
I have done two things on the attached drawing that I think are questionable:
1. I have called a datum feature of size from a reference dimension (Datum A and B)
2. I have shown a feature of size datum as a center line in another view to dimension from it (Datum B - defined in bottom view, referenced in front view)
It seems to me that it is acceptable to use a feature of size that is not controlled on this drawing as a datum as long as I do not reference material condition (it will be RMB).
I have seen people say that there should never be a datum symbol attached to a center line, but I'm not seeing a better way to represent it in the view I am using.
My intention is to have the two 4.625 dia holes centered on the plate. Does this drawing do that? Is there a better way to do that?
Thanks,
Matt
Thanks,
Matt
