I am trying to get a journal to report file paths of all components contained within the RootComponent, whether they a loaded or not.
I started with some code I found on NXJournaling.com that lists the names of all the files.
I have been unable to convert a component to a part so I can use .fullpath and have been unable to find any other way to retrieve the file path.
Any help would would be greatly appreciated!
Kevin
'Journal to recursively walk through the assembly structure
' will run on assemblies or piece parts
' will step through all components of the displayed part
'NX 7.5, native
'NXJournaling.com February 24, 2012
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen.Utilities
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Dim prototype As Part
Sub Main()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
lw.Open
Try
'Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
lw.WriteLine(workPart.fullpath.ToString)
'*** end of code to process root component
ReportComponentChildren(c.RootComponent, 0)
else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
lw.Close
End Sub
Sub reportComponentChildren( ByVal comp As Component, _
ByVal indent As Integer)
For Each child As Component In comp.GetChildren()
'*** insert code to process component or subassembly
'lw.WriteLine(child.Part.FullPath.ToString)
prototype = CType(child.Prototype, Part)
lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
'*** end of code to process component or subassembly
if child.GetChildren.Length <> 0 then
'*** this is a subassembly, add code specific to subassemblies
lw.WriteLine(New String(" ", indent * 2) & _
"* subassembly with " & _
child.GetChildren.Length & " components")
" + Active Arrangement: " & _
child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
'*** end of code to process subassembly
else
'this component has no children (it is a leaf node)
'add any code specific to bottom level components
end if
reportComponentChildren(child, indent + 1)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Kevin
'NX 7.5, native
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports System.IO
Module NXJournal
Sub Main()
lw.Open
Try
else
end if
End Try
lw.Close
End Sub
else
end if
Next
End Sub
End Function
End Module
