Dear Gentlemen,
I've been rebuilding the supercharger from 1989 Toyota MR2. Here in the States, the car is officially an antique. The supercharger is an OEM factory (Toyota SC12), self contained unit which has a pair of flat roots-type paddles. I am having trouble finding replacements for the oddly dimensioned front bearings that measure 17mm bore, 45mm outer diameter and 14mm in depth. It's the 45mm outer that is absolutely impossible to find... off-the-shelf items tend to be 40mm or 47mm. If this were a money-no-object project, I could order custom bearings. Cheaper yet, I could bore the mounts to 47mm but I'm trying to avoid those expenses, if I can. I was wondering if the problem could be solved by pouring a hard setting compound around smaller 40mm bearings. Liquid Metal is advertised as being pretty tough. I was also considering the use of a high-temperature binary plastic called Novolac 555. Is it likely either of these compounds would adequately hold a 40mm bearing placed inside a 45mm mount? Does anyone know of a company that stocks odd-ball sized bearings?
Walter Carter, Palm Springs, CA
