Replace ANSYS Workbench Watermark?
Penguineer
21
Is it possible to replace the watermark in ANSYS v15.0 workbench with something more personalized? I know in previous versions this was possible as explained below:
There is a file in the installation folder called ANSYS_150.png that contains the watermark image used in DM, Mechanical, Meshing, and FE Modeler. It’s located:
C:\Program Files\Ansys Inc\v121\aisol\CommonFiles\Bitmaps\ANSYS_150.png. The users can make their own watermark file and replace the ANSYS_150.png file (though I’d recommend making a backup copy of the original file first).
However, this directory no longer exists in the v15.0 folder directory and apparently this image file is not there as well. Any help is appreciated.
Thank you.
