brentna
- Dec 1, 2008
- 2
I’m trying to find the best way to patch a hole in a NEMA 4x panel box. In order to mount a temp stat sensor onto the box we were required to run the wires into the box. The Stat sensor is an open device and a gasket behind the stat would not properly shield the hole from the outside environment. What would be the best way to seal the hole to maintain the NEMA 4x rating?
