Repairing a National Board Registered heat exchanger using a non-R-Stamp company
jeevesme
Petroleum
We have an ASME built and NB registered Heat Exchanger that we need to put new tubes in. It has seal-welded 2205 tubes in it and we would like to put 316L tubes in it (because of time constraints) using a non-R-Stamp shop (because of time constraints). This unit operates below 15psig so the Illinois BPV law does not apply.
1. Since this has a NB Number, we still have to have an R-Stamp company re-tube it, correct?
2. If we have a company without an R-Stamp re-tube it(and the answer to the above question is yes), it is no longer compliant with NB-23, correct?
3. If the answer the #2 is yes:
Do we need to document somewhere that the unit was not repaired in compliance with NB-23?
How would this affect future repairs?
Since you're in Illinois, what does the Chief Boiler Inspector say on the matter? That would be your first call, not here. Specifically because Illinois keeps a record of each ASME boiler and vessel. They will probably say you can rip the nameplate off and de-classify it as an ASME vessel.
Also, if you get an answer from the Chief Inspector, I would contact your Pressure Vessel Insurance.
Separately from what they each say. A R-stamp company required to maintain the ASME pedigree of the vessel. Keeping it an ASME vessel maintains re-sell value.
Quality is not an act, it is a habit - Aristotle
Excellent recommendations from former AIS.I might add any conversations with Jurisdiction or Insurance Co. get in writing and file away.
My guess is this is a cost issue. Do it the correct way.
The Chief, unfortunately, was not much help. He basically just said that since it operates under 15 psig, Illinois doesn't care. We ended up plugging tubes and ordering a new heat exchanger. FYI, Material availability was the issue, not cost.
