friartuck
- May 31, 2004
- 402
I am currently working for a client who wishes to use renewable energy.
Whilst I would like to think that I am a 'green' engineer, I am finding it difficult to find a suitable renewable energy source.
I am sure that there are plenty of systems out there, but in the UK climate, I am finding it difficult to justify there use.(please note that I am not anti-renewable energy, I just need a system that I can justify)
My findings so far are as follows:
a. PV Cells
Ridiculously expensive. (£4500-00 per kWp kilo Watt peak)With meaningless pay back periods. (The solar array would need to be replaced before the system has had time to pay back)
Typically PV cells are only 12-14% efficient and outputs are based on 1000W/m2 (i.e. the panel is located in the sunny tropics--not cloudy old Britain-where the solar intensity is generally less than half of this)
b. Water Solar (To heat hot water for domestic use)
Comments similar to the above. Payback is a little better. Orientation is very important and in my instance, the building roof is poorly oriented.
c. Ground Source Heat Pump (Boreholes)
Clients don't want to pay out a few thousand pounds to see if the land has a suitable heat source.
Also, many are anti ''underfloor heating'' (Required in order to use the low grade heat source)
d. GSHP-Slinky Coils
We don't seem to have enough land to put the thousands of metres of coils.
Plus when you add all the ancillary items like ground works, borehole digging, maintenance etc, the costs get really high.
e. Wind Power
Nobody likes to look at these. We get protests from planning and again, the payback depends on the location of the turbine.
I have found that in our windy climate, these can be cost effective (which surprised me)
f. BioMass (Wood pellet Burning)
This worked out quite cost effective. The wood pellets are very cheap to buy and running costs were low. Pay back was around 8-10 years but maintenance costs made the overall scenario more expensive.
We also needed high chimneys (clean air act), full stainless steel chimneys, a large fuel bunker and a bigger plant room. The fuel is classed as carbon neutral and I made this option the best of all the bunch.
Concerns
It seems that trying to justify renewable energy is difficult when you know that the plant will never pay back.
I am also unsure (even on ecological grounds) if putting something like solar PV cells is actually worth it.
Are we causing MORE damage to the planet by using something like this. I could understand it if costs were low and payback quick (i.e. paybacks of less than say 10-15 years)
But if a system has to be replaced even before it has paid for itself, then are we causing more damage--(and doing the 'green thing' for the wrong reasons.
Carbon Burden
Another thing that I find hard to understand is that we utilise renewable energy so that we can reduce the amount of carbon used.
Are we sometimes in danger of actually using more carbon by using some of these less efficient methods of renewable energy. I would guess if we took into account the extra carbon needed to replace/maintain plant, then the whole exercise was probably a waste of time and caused more damage to mother earth.
I am sure I have opened a can of worms here, but I would be interested to hear other peoples views.
I look forward to receiving the benefit of your experience
Tucky
Friar Tuck of Sherwood
a. PV Cells
e. Wind Power
Concerns
Carbon Burden
Tucky
