Rendering ---- room textures help!
  • Thread starter Thread starter chuachinghong
  • Start date Start date
C
chuachinghong
Guest
Hi I am a newbie in proE and I am using the older version of proE, proE2001.I need some cool textures for room creation.
Well, I have been searching the internet for quite sometime and I just could not finda good combinations of textures(i.e. textures for the floor, two walls)just like the previoustopic on "proE Rendering".Can anyone help me,if possible,give me some of the links/website where you have gotten those cool textures. Thanks for your help!!!
Hi,, what kind of textures are yo looking for? what kind of scene have you in mind? what parts are you trying to render? are you usign Phorolus (ARX) or pro/photorender?
it depends on the parts, but I usually try to not show the walls, I also ry to keep the floor quite simple, generally single tone.. luse the lights to "highlight" the appropriate areas.. try to keep your model the center (not physical center but the focal point) of you rendered image..
let me know if I can help out more!
James
can anybody give a graphics library for rendering, i cant download graphic library in ptc bcause dont have account nmber. pls send it to me
it's a couple of hundred megs so e-mail is out of the question.. if you bought ProE then I believe it should have been on a cd somewhere... I'm open to correction on this..
James
Okay thanks for your help...!Well I am using proE(version 2001)photorender and I think that the results of rendering is not as good as compared to ARX, by the way is rendering in Wildfire superior than proE 2001?
For materials library get on
<a href="http://www.facebook.com/pages/CreoARX/249926328400211" target="_blank">
Creo Arx Community</a>
Edited by: Parra
