rename_drawings_with_object
  • Thread starter Thread starter KK_designer
  • Start date Start date
K
KK_designer
Guest
What exactly this config command do (described in title) ?
If I had this command with BOTH value, I suppose that when I rename assembly or part, drawing name will also change ?
What is the main rule to apply this config command in pro-e, step by step (example: do I need to open new part/assy with associated drawing what pro-e gives me on part start creation) ?
I notice this command in config.sup file, and not in config.pro which I´m using
I´m working offline Windchill
This command is for when you do a "Save As" to a part or assembly. If the drawing name is the same as the part or assembly name, the drawings will be copied over with the new name you saved the part/assembly as.
