All of my individual projects are stored in a master folder called "DRAFT". In most cases (95%) all project files are located only within the project subfolder, so I could rename that master folder until the cows come home--the references would fix themselves (find the files in the folder).
But for the other five percent, files in one project folder might reference files in a different project folder. In those cases, renaming the master folder would permanently break the links, and mayhem would ensue.
Is there a way (in vanilla SW or with a macro somebody has written) to either LIST references or FIX references? If they're listed, I could manually fix after renaming the master folder; if they're fixed, then it's even easier.
Why would I do that, you ask? Because I didn't plan my folder structure properly when I implemented SW and I'd like to redo it now before we get too far down the road.
Also--I know about PDMWorks and what it's capable of; it's just not a fit for our company.
I look forward to your responses. Thanks!
Brian
Brian
